#include “stm32f10x.h”
#include “stm32f10x_gpio.h”
#include “stm32f10x_rcc.h”
#include “stm32f10x_usart.h”
#include <stdio.h>
#include “soft_i2c_ultrasonic.h”
- USART1 接口
- PA9 → USART1_TX
- PA10 → USART1_RX
#define UART_GPIO_RCC RCC_APB2Periph_GPIOA
#define UART_GPIO GPIOA
#define UART_TX_PIN GPIO_Pin_9
#define UART_RX_PIN GPIO_Pin_10
简单毫秒延时
static void Delay_Ms(uint32_t ms)
volatile uint32_t count;while (ms-- != 0U)
count = SystemCoreClock / 8000U;while (count-- != 0U) { __NOP(); }}
USART1 初始化
波特率:115200
数据位:8
停止位:1
无校验
static void USART1_Init_115200(void)
GPIO_InitTypeDef gpio;
USART_InitTypeDef usart;RCC_APB2PeriphClockCmd(
UART_GPIO_RCC | RCC_APB2Periph_USART1,
ENABLE
- PA9:USART1_TX
gpio.GPIO_Pin = UART_TX_PIN;
gpio.GPIO_Speed = GPIO_Speed_50MHz;
gpio.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(UART_GPIO, &gpio);
- PA10:USART1_RX
gpio.GPIO_Pin = UART_RX_PIN;
gpio.GPIO_Mode = GPIO_Mode_IN_FLOATING;
USART_StructInit(&usart);
usart.USART_BaudRate = 115200U;
usart.USART_Mode =
USART_Mode_Tx |
USART_Mode_Rx;USART_Init(USART1, &usart);
USART_Cmd(USART1, ENABLE);
} - PA9:USART1_TX
printf 重定向到 USART1
int fputc(int ch, FILE *stream)
(void)stream;USART_SendData(USART1, (uint8_t)ch);
while (USART_GetFlagStatus(
USART1,
USART_FLAG_TXE
) == RESET)
}return ch;
int main(void)
uint16_t distance_mm;
UltrasonicI2CStatus status;
uint8_t address;
uint8_t found;
SystemInit();
USART1_Init_115200();
SoftI2C_Ultrasonic_Init();
printf(
"Ultrasonic ready, I2C=100kHz, address=0x%02X\r\n",
ULTRASONIC_I2C_ADDR
* 检查 I2C 总线空闲电平
* 正常应显示:
* I2C idle: SCL=1 SDA=1
printf(
"I2C idle: SCL=%u SDA=%u\r\n",
SoftI2C_Ultrasonic_SclHigh(),
SoftI2C_Ultrasonic_SdaHigh()
* 扫描 7 位 I2C 地址
printf("I2C scan:");
found = 0U;
for (address = 0x08U;
address <= 0x77U;
address++)
if (SoftI2C_Ultrasonic_Probe(address))
printf(" 0x%02X", address);
found = 1U;
if (!found)
printf(" no device");
printf("\r\n");
while (1)
status =
SoftI2C_Ultrasonic_ReadDistance(
&distance_mm
if (status == ULTRASONIC_I2C_OK)
printf(
"distance: %u mm (%u.%u cm)\r\n",
distance_mm,
distance_mm / 10U,
distance_mm % 10U
else
printf(
"I2C error, stage=%u\r\n",
status
Delay_Ms(100);
#define SCL_HIGH()
GPIO_SetBits(ULTRASONIC_I2C_GPIO, ULTRASONIC_I2C_SCL_PIN)
#define SCL_LOW()
GPIO_ResetBits(ULTRASONIC_I2C_GPIO, ULTRASONIC_I2C_SCL_PIN)
#define SDA_HIGH()
GPIO_SetBits(ULTRASONIC_I2C_GPIO, ULTRASONIC_I2C_SDA_PIN)
#define SDA_LOW()
GPIO_ResetBits(ULTRASONIC_I2C_GPIO, ULTRASONIC_I2C_SDA_PIN)
#define SDA_READ()
GPIO_ReadInputDataBit(ULTRASONIC_I2C_GPIO, ULTRASONIC_I2C_SDA_PIN)
软件延时
该延时采用较保守的配置,保证 I2C 处于标准模式范围。
如果 SystemCoreClock = 72 MHz,实际频率会低于 100 kHz。
static void SoftI2C_Delay(void)
volatile uint32_t count;count = SystemCoreClock / 200000U;
__NOP();
I2C 起始信号
static void SoftI2C_Start(void)
SDA_HIGH();
SCL_HIGH();
SoftI2C_Delay();SDA_LOW();
SoftI2C_Delay();SCL_LOW();
I2C 停止信号
static void SoftI2C_Stop(void)
SDA_LOW();
SoftI2C_Delay();SCL_HIGH();
SoftI2C_Delay();SDA_HIGH();
SoftI2C_Delay();
等待从机应答
返回:
1:收到 ACK
0:没有收到 ACK
static uint8_t SoftI2C_WaitAck(void)
uint16_t timeout = 0U;/*
- 释放 SDA,让从机控制 SDA
SDA_HIGH();
SoftI2C_Delay();
SCL_HIGH();
SoftI2C_Delay();while (SDA_READ() != Bit_RESET)
timeout++;if (timeout > 1000U) { SCL_LOW(); return 0U; }}
SCL_LOW();
return 1U;
} - 释放 SDA,让从机控制 SDA
软件 I2C 写一个字节
static uint8_t SoftI2C_WriteByte(uint8_t data)
uint8_t bit;for (bit = 0U; bit < 8U; bit++)
if ((data & 0x80U) != 0U)
SDA_HIGH();
else
SDA_LOW();
}data <<= 1; SoftI2C_Delay(); SCL_HIGH(); SoftI2C_Delay(); SCL_LOW();}
return SoftI2C_WaitAck();
软件 I2C 读一个字节
ack = 1:读取后发送 ACK
ack = 0:读取后发送 NACK
static uint8_t SoftI2C_ReadByte(uint8_t ack)
uint8_t bit;
uint8_t data = 0U;/*
- 释放 SDA,让从机输出数据
SDA_HIGH();
data <<= 1;SCL_HIGH(); SoftI2C_Delay(); if (SDA_READ() != Bit_RESET) { data |= 1U; } SCL_LOW(); SoftI2C_Delay();}
- 主机发送 ACK 或 NACK
if (ack != 0U)
SDA_LOW();
else
SDA_HIGH();
SoftI2C_Delay();
SCL_HIGH();
SDA_HIGH();return data;
} - 释放 SDA,让从机输出数据
软件 I2C 初始化
void SoftI2C_Ultrasonic_Init(void)
GPIO_InitTypeDef gpio;RCC_APB2PeriphClockCmd(
ULTRASONIC_I2C_GPIO_RCC,
ENABLE
);gpio.GPIO_Pin =
ULTRASONIC_I2C_SCL_PIN |
ULTRASONIC_I2C_SDA_PIN;gpio.GPIO_Speed = GPIO_Speed_2MHz;
gpio.GPIO_Mode = GPIO_Mode_Out_OD;GPIO_Init(ULTRASONIC_I2C_GPIO, &gpio);
- 释放总线
SCL_HIGH();
SDA_HIGH();
SoftI2C_Delay();
} - 释放总线
- 检查 SCL 当前是否为高电平
uint8_t SoftI2C_Ultrasonic_SclHigh(void)
return GPIO_ReadInputDataBit(
) == Bit_SET;
- 检查 SDA 当前是否为高电平
uint8_t SoftI2C_Ultrasonic_SdaHigh(void)
) == Bit_SET;
探测一个 I2C 设备地址
address 使用 7 位地址,例如:
0x77,而不是 0xEE 或 0xEF。
返回:
1:设备应答
0:设备无应答
uint8_t SoftI2C_Ultrasonic_Probe(uint8_t address)
uint8_t ack;if (address > 0x7FU)
return 0U;
}SoftI2C_Start();
- 探测时发送写地址:
- 7 位地址左移 1 位
ack = SoftI2C_WriteByte(
(uint8_t)(address << 1)
SoftI2C_Stop();
return ack;
读取超声波距离
读取格式:
- 发送写地址 0xEE
- 发送寄存器地址 0x00
- 重复起始
- 发送读地址 0xEF
- 读取低字节
- 读取高字节
UltrasonicI2CStatus SoftI2C_Ultrasonic_ReadDistance(
uint16_t *distance_mm
uint8_t low;
uint8_t high;
if (distance_mm == 0)
return ULTRASONIC_I2C_BAD_ARGUMENT;
- 起始信号
SoftI2C_Start();
发送写地址 0xEE
if (!SoftI2C_WriteByte(
(uint8_t)(ULTRASONIC_I2C_ADDR << 1)
SoftI2C_Stop();return ULTRASONIC_I2C_ADDRESS_NACK;
发送距离寄存器地址 0x00
ULTRASONIC_DISTANCE_REG
SoftI2C_Stop();return ULTRASONIC_I2C_REGISTER_NACK;
- 重复起始
SoftI2C_Start();
发送读地址 0xEF
(uint8_t)((ULTRASONIC_I2C_ADDR << 1) | 1U)
SoftI2C_Stop();return ULTRASONIC_I2C_READ_ADDRESS_NACK;
- 先读取低字节,再读取高字节
low = SoftI2C_ReadByte(1U);
high = SoftI2C_ReadByte(0U);
SoftI2C_Stop();
- 距离单位为毫米
*distance_mm =
(uint16_t)(((uint16_t)high << 8) | low);
return ULTRASONIC_I2C_OK;
} - 读取高字节
#ifndef __SOFT_I2C_ULTRASONIC_H
#define __SOFT_I2C_ULTRASONIC_H
- 软件 I2C 引脚配置
- 当前接线:
- PB6 → SCL
- PB7 → SDA
#define ULTRASONIC_I2C_GPIO GPIOB
#define ULTRASONIC_I2C_GPIO_RCC RCC_APB2Periph_GPIOB
#define ULTRASONIC_I2C_SCL_PIN GPIO_Pin_6
#define ULTRASONIC_I2C_SDA_PIN GPIO_Pin_7
- 商家代码确认:
- 7 位地址为 0x77
- 写地址为 0xEE
- 读地址为 0xEF
#define ULTRASONIC_I2C_ADDR 0x77U
- 距离寄存器:
- 0x00:距离低字节
- 0x01:距离高字节
#define ULTRASONIC_DISTANCE_REG 0x00U
typedef enum
ULTRASONIC_I2C_OK = 0,
ULTRASONIC_I2C_BAD_ARGUMENT,
ULTRASONIC_I2C_ADDRESS_NACK,
ULTRASONIC_I2C_REGISTER_NACK,
} UltrasonicI2CStatus;
void SoftI2C_Ultrasonic_Init(void);
uint8_t SoftI2C_Ultrasonic_SclHigh(void);
uint8_t SoftI2C_Ultrasonic_SdaHigh(void);
uint8_t SoftI2C_Ultrasonic_Probe(uint8_t address);
#endif
