产品型号 / 套件:SO_ARM101
版本 / 规格:标准版
问题描述:主臂和从臂的3号电机一直找不到 6号电机有时候有有时候没有。
lerobot-calibrate --teleop.type=so101_leader --teleop.port=COM11 --teleop.id=my_awesome_leader_arm
INFO 2026-08-31 21:04:08 calibrate.py:75 {‘robot’: None,
‘teleop’: {‘calibration_dir’: None,
‘id’: ‘my_awesome_leader_arm’,
‘port’: ‘COM11’,
‘use_degrees’: False}}
Traceback (most recent call last):
File “D:\program\conda\envs\lerobot\lib\runpy.py”, line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File “D:\program\conda\envs\lerobot\lib\runpy.py”, line 86, in run_code
exec(code, run_globals)
File "D:\program\conda\envs\lerobot\Scripts\lerobot-calibrate.exe_main.py", line 5, in
File “D:\project\lerobot\src\lerobot\calibrate.py”, line 88, in main
calibrate()
File “D:\program\conda\envs\lerobot\lib\site-packages\draccus\argparsing.py”, line 225, in wrapper_inner
response = fn(cfg, *args, **kwargs)
File “D:\project\lerobot\src\lerobot\calibrate.py”, line 82, in calibrate
device.connect(calibrate=False)
File “D:\project\lerobot\src\lerobot\teleoperators\so101_leader\so101_leader.py”, line 74, in connect
self.bus.connect()
File “D:\project\lerobot\src\lerobot\motors\motors_bus.py”, line 436, in connect
self._connect(handshake)
File “D:\project\lerobot\src\lerobot\motors\motors_bus.py”, line 445, in _connect
self._handshake()
File “D:\project\lerobot\src\lerobot\motors\feetech\feetech.py”, line 167, in _handshake
self._assert_motors_exist()
File “D:\project\lerobot\src\lerobot\motors\motors_bus.py”, line 409, in _assert_motors_exist
raise RuntimeError(“\n”.join(error_lines))
RuntimeError: FeetechMotorsBus motor check failed on port ‘COM11’:
Missing motor IDs:
- 3 (expected model: 777)
Full expected motor list (id: model_number):
{1: 777, 2: 777, 3: 777, 4: 777, 5: 777, 6: 777}
Full found motor list (id: model_number):
{1: 777, 2: 777, 4: 777, 5: 777, 6: 777}
重新插拔主板电源和数据线;单独一台机械臂连接电脑;
多次执行命令结果如下
(lerobot) D:\project\lerobot>python -c “from lerobot.motors.feetech import FeetechMotorsBus; bus=FeetechMotorsBus(‘COM10’,{}); bus._connect(False); bus.set_baudrate(1000000); print({i:bus.ping(i) for i in range(1,7)}); bus.disconnect(False)”
{1: 777, 2: 777, 3: None, 4: 777, 5: 777, 6: None}
{1: 777, 2: 777, 3: None, 4: 777, 5: 777, 6: 777}
(lerobot) D:\project\lerobot>python -c “import time; from lerobot.motors.feetech import FeetechMotorsBus; bus=FeetechMotorsBus(‘COM10’,{}); bus._connect(False); bus.set_baudrate(1000000); [print(‘6=’, bus.ping(6, num_retry=5)) or time.sleep(0.3) for _ in range(50)]; bus.disconnect(False)”
6= 777
6= 777
6= None
6= None
6= None
6= None
6= None
6= None
6= None
6= 777
6= 777
6= 777
6= 777
6= 777
6= 777
6= 777
6= 777
6= 777
6= 777
6= 777
6= 777
执行这个6号电机有时候有有时候没有
(lerobot) D:\project\lerobot>python -c “import time; from lerobot.motors.feetech import FeetechMotorsBus; bus=FeetechMotorsBus(‘COM11’,{}); bus._connect(False); bus.set_baudrate(1000000); [print(‘3=’, bus.ping(3, num_retry=5)) or time.sleep(0.3) for _ in range(50)]; bus.disconnect(False)”
3= None
3= None
3= None
3= None
3= None
3= None
3= None
3= None
3= None
3= None
3= None
3= None
3= None
3= None
3= None
执行这个 3号机电一直没有
