产品型号 / 套件:So-ARM101 diy散件
操作系统 / 软件 / 固件版本:Ubuntu 22.04
问题描述:可以进行遥操作,但从臂5号舵机无法跟随主臂进行转动,并且每次遥操作前都显示连不上5号与6号舵机,需要插拔一次电源线才能进行遥操
报错信息 / 日志 / 截图:INFO 2026-10-16 14:44:44 eoperate.py:137 {‘display_data’: False,
‘fps’: 60,
‘robot’: {‘calibration_dir’: None,
‘cameras’: {},
‘disable_torque_on_disconnect’: True,
‘id’: ‘follower’,
‘max_relative_target’: None,
‘port’: ‘/dev/ttyACM0’,
‘use_degrees’: False},
‘teleop’: {‘calibration_dir’: None,
‘id’: ‘leader’,
‘port’: ‘/dev/ttyACM1’,
‘teleop_time_s’: None}
INFO 2026-10-16 14:44:44 01_leader.py:82 leader SO101Leader connected.
INFO 2026-10-16 14:44:44 follower.py:104 follower SO101Follower connected.
Traceback (most recent call last):
File “/home/henry/robot_learning/So101/envs/lerobot/bin/lerobot-teleoperate”, line 6, in
sys.exit(main()) -3.87
File “/home/henry/robot_learning/So101/lerobot/src/lerobot/teleoperate.py”, line 159, in main
teleoperate() | 100.00
File “/home/henry/robot_learning/So101/envs/lerobot/lib/python3.10/site-packages/draccus/argparsing.py”, line 225, in wrapper_inner
response = fn(cfg, *args, **kwargs)
File “/home/henry/robot_learning/So101/lerobot/src/lerobot/teleoperate.py”, line 155, in teleoperate
robot.disconnect()
File “/home/henry/robot_learning/So101/lerobot/src/lerobot/robots/so101_follower/so101_follower.py”, line 226, in disconnect
self.bus.disconnect(self.config.disable_torque_on_disconnect)
File “/home/henry/robot_learning/So101/lerobot/src/lerobot/motors/motors_bus.py”, line 472, in disconnect
self.disable_torque(num_retry=5)
File “/home/henry/robot_learning/So101/lerobot/src/lerobot/motors/feetech/feetech.py”, line 298, in disable_torque
self.write(“Torque_Enable”, motor, TorqueMode.DISABLED.value, num_retry=num_retry)
File “/home/henry/robot_learning/So101/lerobot/src/lerobot/motors/motors_bus.py”, line 1023, in write
self.write(addr, length, id, value, num_retry=num_retry, raise_on_error=True, err_msg=err_msg)
File “/home/henry/robot_learning/So101/lerobot/src/lerobot/motors/motors_bus.py”, line 1049, in write
raise RuntimeError(f"{err_msg} {self.packet_handler.getRxPacketError(error)}")
RuntimeError: Failed to write ‘Torque_Enable’ on id=5 with ‘0’ after 6 tries. [RxPacketError] Overload error!
已尝试的排查:1.重新校准
2.重新插拔5号舵机连接线
